Vinz.Clortho
Member
I had posted earlier about my shift kit body valve spacer plates bolt holes not lining up and 2 are way off. Started to research and could not find the main body valve pn (2801856) in the 67 Mopar parts catalog. Can't find it in 68 or 69 either. It has a 67 stamp on it. the valve body plate comes up correct (2801295) and the transmission number from the oil pan connection flange matches my 67' 273 cu in 2bbl barracuda. Valve bodies from other lines that year come close but not this one (there's a 2801865). Before this rebuild, nobody could ever get my kickdown to work. I'm hoping this might be the cause if it's incorrect part. Does anyone have any clue where this came from.
Thanks in advance.
Vinz
Thanks in advance.
Vinz
