MoreDart
Active Member
I was driving down the road in my 72 Dart (pictured in profile) with a SB 360. It has run fine, minus running a little rich- but none the less, has not ever caused me a problem. Anyways, I came up to a stoplight and the car just DIES. I cranked over the engine several times to try and get it to start but no dice. When the tow truck brought it home to me I started to replace all the ignition components (Ballast resistor, MSD 6AL box, Blaster 2 coil compatible with 6AL, OEM distributor, Cap, Rotor, Wires, Plugs) Right now I have narrowed it down to 1 thing, and that is the spark plugs are not getting any spark. I have read alot about the issue and I dont feel as though I am an idiot but I just dont understand what could cause this. I have red-blueish spark coming out of the coil when I test the MSD box, and all the wires are hooked up correctly, and I dont think it would be the Stator (or pickup coil) because that was just replaced with a brand new one; and I also regrounded the engine on the frame steel to steel. The original set up in the car when it had broken down was a MSD 6A box, Accel coil, OEM distributor, Accel 8mm wires and Bosch coppertops. All we replaced to replicate what was in it originally minus the 6AL box. Like I was saying, COIL=SPARK, PLUG=NO SPARK. Mopar gods be kind to me, and please let me know what I am doing wrong!
