roccodart440
- Joined
- Apr 19, 2010
- Messages
- 6,812
- Reaction score
- 3,595
A while back the car all of a sudden started to idle really low and want to die, unless I gave it throttle.
Changed the filter, PCV and pulled the carb and the baseplate of the carb was loose. Tightened it up and re-torqued with Loctite. Problem seemed to go away.
Now it's back. Car just won the day at the strip last weekend and had it out all day yesterday and was running lie a top. All of a sudden idle wants to drop out.
Now i'm leaning towards getting a batch of bad gas as This came shortly after I filled the tank from being on E. Last time I had the issue the last place I got gas was at the same place. Fuel is 93 octane from stewarts with ethanol (all pumps in NYS have this)
Car doesn't miss going down the road at any speed or under load. Float levels are spot on.
go......
go......
