What kind of change could I be looking at by going with a carb spacer? Which is better a 1/2" or 1"?
I need to get more air at mid to full throttle acceleration. That is the only area of my setup that is a little rich. Under hard accel, it sounds like its going strong, but if I back off a little the RPMs don't change put it starts to pull. I can't find the right metering rod that will lean it up in the WOT and stay the same in cruse mode.
Any thoughts?
Any thoughts?
