Carb woes
I've done the freezer trick when putting Pistons into a drum when rebuilding a trans.
The 1945 carb acc pump well fills from top there is no check ball.As fuel evaporates from the carb fuel level will drop below the spillway to pump well. It will stop working until fuel is restoed. On more thing the float some times can drag along the wall of carb.
I'm gonna buy a couple of the 11/16 caps. All the ones I have currently are the 22/32 ones.
Hopefully they arrive before the snow gets here!
11/16 = 22/32.... what's the difference there? other than unit of measure....
Woops.
It's 11/16 and 23/32.
And this carb ran great til I rebuilt it, so something just isn't right that's in there, replacing it would be silly. Especially when I have two and it's just this one issue.
When you set the manual choke, is it pushing the choke valve fully closed? There needs to be a gap between the blade and the bore so some air can be let in.
I'm lucky to have a BBS on mine. Hot start or cold, engine runs perfectly. It is a very simple carb. The 1920 Holley seems to be more complex and unreliable.
I was just looking at a 1973 FSM and it flat out says that if there is excessive throttle shaft wear in body then the carb should be replaced. Period. No other discussion.
But the 1968 manual goes into further detail: "During manufacture, the location of the idle transfer port and the spark advance control ports to the throttle valve is carefully established for one particular assembly. If a new shaft should be installed in an old, worn body, it would be very unlikely that the original relationship of the ports to the valve would be obtained." It affects operation between 15 and 30 mph.
Wow, that's enough of a condemnation for me , among others, to start looking for a BBS over the winter. Maybe a 60's vintage. There's been a lot of complaints about how rebuilt parts are a crap shoot these days. Alternators, carbs, starters, etc. FSM's go into great detail about carb adjustments. What are the odds that a mass rebuilder takes the time? Could be a good indoor project for you over the winter though.
This newer gas evaporates quickly. I don thave a slant but my 340 would"long crank " after a heat soak. I installed a heat spacer under the carb.it seemed to help. It also helps if the car sits a day or three, basically the gas doesn't flash off quickly in the bowl from the heat.
