@AndyF How do you wire up the second o2 sensor? I do not see that in the instructions
Please post links to the documents you are referring to.
Its just different.1. Is MSD 6a just a better form of electronic ignition?
Not really. Did you read or watch the master tech stuff on carburetor fundementals?3. Is there any benefit to running an electric fuel pump with a return to a carburetor?
I'm just a guy with a garage and some tools. I have no formal mechanical training. So please dumb these answers down. I have never owned a car with a carburetor till now.
That's cool. As long as you know the whole thing will be a journey, including the troubleshooting and tuning, then you won't have the regrets that those that think it (EFI) is a plug and chug. Enjoy the journey.Its more about learning as much as I can before I do it.
I want to go to EFI for easier starting. The car takes a enough energy to start already. I also would like to take a few road trips and I don't want elevation, etc. to cause me problems after sitting overnight. The wiring on this car is pretty old. Starting the car I have to pump the pedal 3 times, turn the key and keep my foot on the pedal for a minute or two. After that the car may decide to stay on or it may cutoff. I am willing to do what it takes to stop doing this dance with the car when I want to drive it.
Difficult starting is pretty easy to fix then isn't it? LOLGeorge Jets if I had to guess, I would say I am the problem. When the car starts it runs fine. Right now I am learning everything on the fly here.
Hope its wired to the fuse box.I changed a few bulbs, installed a more modern sound system
You're tackling a BIG Project. Get a notebook, file system, clipboard and wrtie stuff down. Coming up with a note system that works for you can take some time. I use all the above plus spreasheets on the computer. Again, whatever works for you so you can find the info again. Also every time you write stuff down it will help you remember. If you watch videos, take notes.I did a post when I first got the car to try and attempt to figure out what carb was on the car. I think it said1450, but I would have to go back and check on that. I remember it had a bold W with a line under it. Could be a knock off for all I know. The ignition is a mopar electric connected to a msd blaster coil (from what I can tell and I could be wrong).
Seems like this is a good starting point! Review what George wrote. Then look in the shop manual and the master tech to get familiar with any terms that don't make sense. Still questions after that; then post them in one of your carb threads.Damn man thats masters level carb speak you got going on there. I'm intrigued. I am going to order this part tomorrow... Nevermind, I just ordered it. Just want to see if these changes make a difference.
