Pawned
N.R.A. Lifetime Member - And damn proud of it
Was this comment aimed at me??? If I even implied that, it was not what I meant.Finally. You seem to assume that you know more than me about carbs, and that may in fact be the case.
I will be the first to say that I am very unfamiliar with carbs
I found no leakage thru the bottom of the carb anymore than a drop or two. I put it back on and will run the car and then see what the temp of the carb bowl are.
As I think back, It has only been the last week or two, since the temps have been in the mid teens (over 100° teens) that it emptied over night. before it took a day or so to empty.
I am going to investigate the evaporation scenario
Regarding the check valves on the pump. I eliminated that possibility by placing a check valve on the fuel line a few inches from the carb
