Carter BBS Slant 170cui idle problems
Green Arrow is the entry point for heated air green dots Is the flow path, red dots are the exit point to manifold vacuum. For Diagnostic and testing purposes I would suggest blocking this off. Black Arrow is PVC entry point you may have to notch your gasket
