HotLines
Realist - Free Thinker
1964 Plymouth Signet.. 91 360, urethane front end and disc brakes, good shocks and a perfect alignment. What is the cure for the center link rubbing against the oil pan? I never had this problem when it was a stock 273 or even the 318 and only slightly with the 340, but now with a 91 360 which has been in the car for a few years, it looks like it's ready to start a hole, which I am sure is not good... What do I need? Thank you... PS, I didn't much mind the 205 70 14's rubbing the fenderwell headers as I added some metal to the bump stop so it would touch the headers and steering works fine
