challenger console and slap stick
I've used the slapstick in an A-body console. Top lever on the vertical rod needs to have a new outer hole 1/4" farther in.
I love the short shifter handle of the E and B body slapstick, the Ebody console is a little too wide but it will fit. I like the look of the A body console better, and is a better fit but I feel like the the short shifter be moved too far forward?
E and 71-74 B body consoles are the same.
IIRC the shifter mount between A, 66-70 B and the slaptick is also the same.
What's different, is the bracket that bolts to the transmission (the one that most people forget to grab when removing console from a parts car). On a B that changes 66-70 and 71-74. bend is slightly different and hole location is offset. Not sure about A.
Late B 75-79 shifters are also the same, but the pawl that makes them ratchet is not there.
They can be converted to "slap" ratchet action.
E body console looks great with the auto stick in that A body. Not sure what mods would be required to mount an E body 4 speed console in an A body 4 speed car.
Maybe if you're tall, but I have found that the shifter is in a good place. I've tried to modify an A-body shifter, but have not come up with a method that works. I may try again one of these days, but I like the short shifter.
Great picture. Do you think this would work with a manual as well? I’m looking to put a 5 speed in my 71 demon. They don’t make a pistol grip for the 5 speed to be used with the console. Curious if I could possibly do this and buy the e body tremac. Did you have to do much to fit this console between the seats? I’m actually down in dayton not to far from you.
Some late B-body shifters were also ratchet shifters. I have one.
I've used the slapstick in an A-body console. Top lever on the vertical rod needs to have a new outer hole 1/4" farther in.View attachment 1715925972
Is the hole modification the only thing that needs to be done......Then it drops right into the factory location using existing rods and brackets? Very nice.....
I am not sure about the 5 speed lining up or not. The console is a tight fit but does fit fine just below the top of the seats.
Would it be possible for you to post more pictures of the console fit? A shot directly above the console looking down between seats. Trying to get a feel for the fit between the seats.
anyone put a challenger console and slap stick in a A body ? we are trying to do something different with our dart
Love that console and the Slap Stick is the best automatic shifter on the planet.
