RockinRobin
Yes.you do have a hole in the top of the vent tube arc don`t you ?!?
tires and torque convertors used to do that for us . A 750 h.p. gen 2 hemi was hard to hook up back then .My little 10 second bracket car slowed down about 5 months ago, and I've tried everything I can think of to identify the problem.
'70 Duster with 750hp GenIII Hemi, all motor, Pro Systems 1050 Dominator, MSD 6Hemi ignition control. Built in 2013.
Ran consistent numbers since 2014, then they started falling off drastically. Losing .1 to .2 on 60ft 1 second on ET 1/4 mile.
New valve springs. Will run smooth at 7500rpm. I usually don't run it past 7000.
Replaced/cleaned everything in the fuel system, no change.
Replaced coils/plugs/ignition controller/batteries in the electrical, no change.
Advanced/retarded timing, jetted up, jetted down, very little change.
Plugs read just about normal.
Any suggestions?? Compression check??
Same brand/size tire this year as always.tires and torque convertors used to do that for us . A 750 h.p. gen 2 hemi was hard to hook up back then .
didn`t catch that. Sounds like a leak test may be needed. bad air ???Same brand/size tire this year as always.
PTC torque converter, could be a good suspect but they only loosen, don't they. I've never heard of one getting tighter. RPM's through the traps are lower than normal.
Bad air for 5 months?didn`t catch that. Sounds like a leak test may be needed. bad air ???
I would presume you would need to know what the lobe lift is supposed to be. B.E.S. racing engines Comp cam custom grind for them. No info. on cam.Cam losing a lobe? Pull valve covers and line up tip of dial indicator in pushrod hole and check lobe lift.
Agreed, just hope the cam and lifters are still ok. Last time I honed a block was over 30 years ago with a drill. Do they still do these modern motors the same way?? Maybe should replace timing chain while I'm at it.Rings,bearings and valve job. Hone the block, gaskets where needed. That's a freshen up. It will be just like new. And should not take long. Not to much money. That's all good!
Thanks! Turns out the motor is just a little worn out from 5 years of drag racing.I would definitely get it honed by a professional. These things with thin rings and such, I would not want the hone too "gritty". Was really hoping it was something stupid simple!
