So i understand the stiffer right rear spring over the left spring and why they built it that way.
just a little info before i go in.
have been freeing up some stiff part in my front end.(aka binding)
See this thread.
Stiff front end looking at aftermarket solutions
SO i'm setting my Ride Height today and it occurs to me that it is taking a LOT more torsion aka pressure on the L side then the right and its still not level.
Before i started on this project the Left side was 2 Inch lower than the Right front side.
I did this because i thought it was a good idea.........
Now it's back together and have been reading in my chassis book(Door Slammers, the chassis book)
I understand better why the Right Rear SS Spring has to be stiffer and taller.............and in return the diagonal load is put on the Left front tire.
Now with all that said
i have been trying to get the Ride Height Equal, between L and R front sides.
This has been difficult, and the torsion bar bolts aka tension is way way tighter on the driver side(left) and it is still lower then the passenger side by a Half of a inch.
Now The Question!!!!!!
Do i call that good or do i keep loosing the passanger side torsion bar and tightening the driver side bar.................or do i let the driver side have that 2 inch drop it had before????
Thanks in advance.
See this thread.
Thanks in advance.
