ok new post ....last one asking if anyone ran pro comp MAGNUM steel heads got off wrong way..lol
looking at building this one a different way ..fun car to beat on light to light ..drive anywhere
kind of ride ...no worrying about getting door dings ext.
here's the picture...can get this weekend a ...$1500 duster roller all new front end parts including disc's ...power steering box ..8 1/4 rear ...body straight ...needs one lower 1/4 patch ...rear seat floor patch ...front seats ..headliner...has new carpet in the box ...was a running driving car he took the motor and trans out ...
complete 360 magnum with 904 on it ....ran when taken out ...i know forget that part ..$250
looking to put this package together for around 4 grand ...i can do all the body work paint ...install work ...put the motor together ext.
going el-cheapo for the drive anywhere fun piece but want BIG low end -mid power to melt tires or go light to light kind of fun ..lol
$100 a gallon single stage paint job but the body straight ...all my labor
$100 summit racing seats
$350 craigslist mags and tires
$150 set of 390 gears
$150 set of headers
$500 misc. rock auto order rad. belts .hoses.battery.alt.oil. filters ext.
$250 in trans ..shift kit rebuild kit
$135 cobra trans. 3500 stall converter
total $3475....appox. cost of car and trans done
now the motor build....using the stock magnum heads if not cracked
$450 have a local head guy will port and 5 angle ...install new springs ....i supply springs
$100 springs
use stock magnum valve train
$550-600 in heads ....fully ported o.e magnums appox. flow at 500 .... 252 / 177
$300 lunati voo-doo hyd. roller 60412.....535 / 550..... 231 / 239 @ 50
$350 machine shop ..clean hone check roller cam bearings in block
$388-rock auto master rebuild kit ...pistons, rings, bearings,gaskets,oil pump, roller chain,freeze plugs
$160 speedmaster air-gap intake
$50 skip white one wire dizzy
$35 summit ign. wires
$175 rebuilt 750 holley double pump
$1833 total ....360 with ported magnum heads ..roller cam 535/550..231/239 @ 50...new pistons..fresh rebuild ...
$3475 car and trans
$1833 motor
$5308 total ....all appox. of course but done with in reason for under 6 grand ....
complete painted duster with fresh power train ....that should roast the tires with 390 gears easy .....
what do you think that motor will pull on the dyno ....seen unported non roller stuff pull of 400 h.p. and torque numbers
.....thinking about also seeing what kind on comp. numbers it would be stock then maybe mill the heads and go for the thin head gasket deal or also deck the block to up her a bit ...
$150 set of headers
$100 springs
$3475 car and trans
$1833 motor
