440-VS
I know you don't want to concider longer shackles, but I had mine made for just a few dollars, they're still not below the body line, and gave me that "inch or 2" I needed on my Duster.
To all the nay-sayers... If you had read the OP's message, he said he was looking for an inch or 2 lift, so that's hardly the weight of the whole car on the shock mounts.
Just for the record, I have Monroe air shocks on my Dart as we speak, and with less than 40lbs of air,they give me the inch or 2 lift I want, and ride great!!
Yes, I will agree if you put 300lbs of air in them, the cars' gonna ride like a stagecoach.
okay let me rephrase that; if you put 40 or so PSI in the shocks and it lifts the car a couple inches you don't think there is 300-400 pounds or more riding on the upper shock mounts? cars that were made to handle weight on the upper shock mounts had big mounts on the top and something called a strut
shocks help with rebound; struts hold weight on a car like A bodies shocks shouldn't be used to lift a car any
air shocks cost what? $100? for that price you can get 2 add a leafs and the U bolts and put an extra leaf in either side
Extra leafs will surely make it ride rougher.
When I first seen the title to this thread I could not help but think of adding an inch or two to something else.......was going to suggest hanging a weight off the end of your......
Take two leaves out of a 72-80 dodge truck,put them in the a body spring pack.Probably raise it more than two,but they do look good.
Old school poor boy way is to add a leaf ot two to the original springs.
Reinsert the bottom with Durango/Dakota leafs that what I did to my 66 70 for the leafs at the junk yard took about 1/2 day that was installing the new rear end too gave me about 2"Discussion on another list.....
Cheapest/easiest way to get an inch or 2 rear lift...
1. New springs
2. Re-arched old springs
3. Air shocks
Don't forget...all I'm asking is for an inch or 2 rear-end lift, not a foot!
( I purposely omitted longer shackles as they look terrible.)
OK...Have At'r!
Here is one more option for you. These are still available from Monroe, but are special order at most part supply houses. The price shown is for a pair, so not really too expensive.
They will raise the rear of your car about an inch or so (if it is sagging due to weak leaf springs) and ride much better than air shocks.
Just another idea to consider. They can also be returned if you are not happy with them. I would order them thru your local parts house so that shipping or returns are not an issue.
http://www.shockwarehouse.com/site/product.cfm?id=18124
LOL. I was thinking the cheapest way would be to take some weight off it.Great link thanks I've been thinking of adding a little bit to the back of my car , mainly for when I make the long road trips with the trunk full of tools and extra fuel
