[Found!] Cheapo generic temperature gauge with a WIRE
cudak888
1-Baker-11
USA
Hello fellows:
The temperature gauge on my '68 Satellite (and the fuel gauge) are dead; pretty sure I have a dead voltage reducer on the back of the instrument cluster.
That said, I still want to do some test runs without tearing into the cluster, and would rather hook up a temperature gauge to the sender and a ground.
Though I have a pile of old gauges in the shed, and it turns out my only temp gauge has a fixed copper line from the gauge all the way to a built-on sender. I'd rather not start splicing hoses or putting tees into the intake to adapt it - I'd rather be able to wire the factory sender up and go.
This said, I'm looking for any old gauge that works and will allow me to do a simple three-wire connection (sender/ground/switched power) to get it working.
PM if you have something.
-Kurt
See my original post - I don't want to go splicing hoses if I can help it. More places to leak, adapters to buy, and not necessarily the best place to pull the temp from.
-Kurt
If you need a down & dirty setup (which could be used for other purposes later), Harbor Freight often has their 3 gauge unit on sale for $9.99. Perhaps that might work for you. GL.
Never thought I'd be happy HF exists. Great idea, thanks for the tip!
Do you have a multi meter? Checking resistance between the sensor tang and chassis ground when cold/hot should give you a clue if the sender is working.
The HF gauges are likely the standard mechanical type, and not the wired electrical-sender unit you're looking for.
I do have a multimeter. I tried grounding the sender wire to the dash, but did not check resistance on the tang to ground. Any range of what I should be looking for?
-Kurt
Cold should be low (sub 100), hot should be several hundred ohms. Could even be done with a pot of water. You're looking for a change of the resistance of more than a few ohms - that's really all that matters.
Will do. At least I'll know if the sender is working or not.
Will still have to dig up a gauge for the test drives.
-Kurt
