Check out what I got!
younggun2.0
federal way, wa
I finally pulled the trigger and bought a bill Mitchell aluminum block! 4.5” bore, cross bolted mains, billet steel caps.
Excellent!
Check it out, well. My friend bought a Mitchell hemi block, and one of the cam bearing bores wasn't finished. They're fixing it.
Looking for 900hp on pump gas. 572” build. 4.5” stroke. 10.7:1 compression, solid roller .700ish lift 270ish @ .050 duration, trick flow 270cc heads, max wedge tunnel ram with twin dominators.
I don't see 900hp being too far out of line for a 572. Do you have the cam yet? I would think you would need something in the 280+ duration and more lift to make that power with those heads. Will you run them OOTB?
