i have thought about doing something simmilar before, i never checked it up real good, but just eyeballing it i think the mopar intake is wider so there should be a possbility to just make some aluminumaddaptor plates out of thick aluminum and get the angles and boltspacing right, sbc uses a wider boltspacing but not sure its wide enough.
i dont think the distributer would be a big problem,just cut that area the same way as it looks on a moparsmallblock, unless the distributor hits the plenum that would be harder to correct.
