Well AJ , I could be wrong, but I wouldn't expect a 220ish at .050 with 110 LSA in a 360 to be super fuel efficient at 1300 rpm , fast rate or not. That might be asking too much. Sounds like it was a great overall package though.
You're not wrong.Well AJ , I could be wrong, but I wouldn't expect a 220ish at .050 with 110 LSA in a 360 to be super fuel efficient at 1300 rpm , fast rate or not. That might be asking too much. Sounds like it was a great overall package though.
Mike Jones .904 grind is really short seat to seat eventhough it's listed at around [email protected] It's 60+ @.275 which is 50% larger than the Mopar Perf 260
I'd like to compare with the Howard's
He can grind it any lsa you want- gives a really flat torque curve I posted a 364 AMC dyno sheet recently
BTW AMC Rambler came with 3'31 with OD with 3.54> 4.11 and even 4.28 optional
we used 3.08 and high 2's in the Mobilgas economy run with the Nash Statesman flathead
If you go over a hill below the OD low limit you can take your foot off the gas and it will not shift into OD so you can coast shut the motor off...
Jim,
It's likely you and I are the only two here old enough to remember the Mobilgas Economy Run... hahaha!!!!!!
Lemmee see if I get this right.I used .275 cus the jones cam peaks around .305 and the DC 260 cam less than 300 so I can't use .300
I have the complete cam doc printouts and .275 made the most sense
where the piston is really pulling on the intake charge around max lift (and later)
.200 is also interesting
at.050 the DC cam is longer than jones and much longer at .004 and seat to seat
Look what I found...
Series for.903″SolidLifters
These profiles are for use with Mechanical Flat tappets with an .903″ diameter or larger. The EMV series profiles are for use in racing applications only, and require the use of our Centra-Lube lifters.
Part # / @ Seat/ .050″/Lifts of 1.5/1.6
CM70325Y/ 280°/230°/.325”/.470”/.500”
CM71375 /284°/238°/.375″/.544″/.580″
CM73375 /292°/246°/.375″/.544″/.580″
CM74375 /296°/250°/.375″/.544″/.580″
CM75405 /300°/254/.405″/.589″/.628″
CM76360-10/304°/250°/.360″/.525″/.560″
Looks like the first lift figure is lobe-lift and the others are net after .020 lash; I'm guessing
Check out that 71375. If that is correct, then that's 46 degrees from .050 to on the seat! Man that's fast
Hey Wyrmrider, what DC cam might you have listed at 284 seat to seat?lol
I couldn't find hydros
Well then mines a dinosaur; it doesn't even list seat to seatThose ramps are considered slow by today's numbers.
My cam is 281 seat to seat and 255 at .050 with a .010-012 lash.
Well, maybe he can chime in and say which. They can be sold. And I agree on the rear gear change later..... but I'd start with the best cam for this app to give it the best shot. For low RPM torque and mileage, LSA need to be pushed towards 114*.Yall I think John already has his camshafts in hand, so all this is a moot point.
Hey AJ, download the Howard's Master Lobe list to seek that fast ramp solid; it shows durations for 'seat' (.006" for hydraulic and .015" for solid), .050", and .200". Plus go down about 3/4 of the way and it will show profiles specifically for the .903" Mopar lifter, both hydraulic and flat.Well then mines a dinosaur; it doesn't even list seat to seat
Downloads | Howards Cams
You're gonna see some very small 'seat'-to-.050" duration differences. These are all 'orderable' through normal sales channels. (I spoke with their customer support a few months ago and it sounded like they prefer you to order through a standard sales outlet.)
Jim,
OK, I thought you were speaking of the .006" spec as essentially the 'seat' point. Not sure what to say... at some point between .000"Thanks nm9, but I don't see anything close to seat to seat; With the .006 spec there could be another 10/15/20 degrees hiding in there, from .006 to closed and not leaking; and nobody knows until you install it and measure it..
That was my point, to get away from that unknown. I know it don't count for much anywhere except fuel economy, idling down the hiway. With 230 or more at .050, that doesn't leave a lot of time for scavenging, and if the exhaust valve takes another 10 or 20 to close, then you're getting down to 90* of scavenging, and so a whole lot of energy is going right out the exhaust. That's what I want to get away from. A wide LSA just aggravates that even more.Yeah, I know closing up the LSA increases overlap. So it becomes a balancing act. Trading one economy-loser for another. That's what makes choosing cams so much fun.
If I swap cams it will be to a solid; then I'll know exactly when the valve is closed. I shouldda done that from the get-go, as often as I have played with my hydros. I thought I could strike a better balance with hydros; power with economy, but in any case not with the HE3037AL,even with 180plus psi.Hey, maybe I'll convert my hydros to solids and see what happens. Yeah I think I could sacrifice some lift and duration.........
I have to think that .004" or .006" is the real number to use, for a good reason: below those lifts, or SOME small lift (for a hydraulic), the flow in or out is just so small as to not make any meaningful contribution to the engine operation. 10 or 20 degrees at essentially zero flow is still essentially zero flow.
I'd suspect (hope?) that was the judgement made by the Chrysler engineers, and the lift used to spec their version was based on what they thought was the lower limit of meaningful flow.
