MDchanic
Connoisseur d'Junque
... I'd still rather have NOS American parts.
Me too.
Besides the DuraLast pump that the PO installed just before he sold me the car lasted less than a year.
– Eric
I have one on the car now that's lasted since January 2018. Same part number.
That's what she said.It's a HARD spring.
– Eric
I don't really know of a way. It could still pull fuel and be bad if the diaphragm spews gas into the crankcase.Its cleaning up pretty nicely, is there a way to test if it is still good for the car?
Nope. You CAN turn the engine so the cam lobe is on the low side, but I've never bothered. Just bolt it on and go.Is there anything unique to installing a pump on the Slant six? Do I have to do the pushrod black magic to get it on? I can't seem to find any guides or videos that actually show the installation for this engine, and I don't want to just try it and screw it up.
It is, actually.Sounds suspiciously easy! I'll see what I can do.
Unless you turn the engine to get the fuel pump lobe on the cam facing the low spot toward the fuel pump hole, yeah you're probably gonna have to manipulate the fuel pump some. I thought I mentioned that.Can't seem to get the bolts to thread back into the engine, do I push down on the pump to get it to go in? I'm alittle confused.
Didn't you just remove them a little bit ago? About that tight.Yeah, I just got it on there, really gotta start hitting the gym lol that kicked my ***. How tight should the bolts be, just as tight as I can get them to go with the wrench?
Pretty stuck now, the pump I have has a "1/2-20 UNF" outlet, and I can't seem to figure out how to get an adaptor to fit that to a 5/16th hose that's currently installed from the previous electrical pump. I'm not really familiar with UNF but if I can just keep the fuel hose and get a connector with a hose barb it would make things a lot easier.
The old mechanical pump was there, but it still had a bit of the old metal line on it, but he just like pinched it off and cut it and the bolt absolutely refuses to come loose, so I can't really reuse that either,
I found a better version of the hose barb you suggest and it should arrive by tomorrow.
Wow, looks like oil change time also.Just got the fuel pump yanked out, much easier from underneath. Some pretty black fluid I assume to be oil came out when it pulled out.
