Anyone got any experience with Clark Welders, bought one from a local farm store a while back, having all sorts of problems with it.
I've had mine for 5 years. No problems. What model is yours? Mine is 220 vt. Can't remember the model. But if you need to know, I'll check it when I get out to the shop.
Is the polarity correct?
I'll throw this in....
Check your wire feed? Maybe the liner is clogging up on you.
Try a different brand / spool of wire?
Bad gas (if using)?
Mine's a 160 EN 220 Volt. I've got years of welding experience with no issues until my lincoln crapped out and i bought this thing. I can't keep a solid, smooth weld going, the spark is literally chattering, I've played with the wire speed on all 9 settings, as well as the other settings. It acts like a dang machine gun the way its sparking up.
Mine is a 180 EN. I use 75/25 gas on mine. I'm still teaching myself to weld, so I'm probably not the best one to ask if it's working correctly. I do know that my welds are beginning to look better though. LOL
Yup, came with everything but the tank. I got mine from ISN, my wholesale tool supplier. Even came with a cheap welding helmet.
Is it possible that by welding on 3/16th steel is too much for this thing? It's supposed to be good for 3/8th
That machine should handle 3/16" without issues I would think.
Loosen up the driver and pull some wire through by hand to "feel" for hang ups.
Is your ground cable clamp and it's connection to the cable tight?
Have you tried welding on some "different" steel and seen the same results?
Shut the power circuit down and check welder plug for loose connections along with the outlet and breaker.
Wire seems to speed smoothly.
I've tried Clark's own brand and Hobart's brand, both same results
No Gas, flux core only.
sounds like how my 10 year old HOBART HANDLER weds, tried everything ..... welds like chit!!!!!! has for the last 10 years !!
What Dave 69 posted. Double check the ground.
Another thing does the wire look deformed coming out of the tip crushed. Tension could be to tight or to loose.
A general way to test if you don't have enough feed pressure is to pull some wire thru bend it slightly then place I against your palm. Pull the trigger. The wire should feed. If not increase tension on rollers if it pushes to fast back off the tension.
