Badart
Senior Member
I am in the process of getting the 73 dart back on the road. Starting out by installing a new urethane bushing kit in the front end. I got side tracked when I saw all of the leaves and pine needles in the drain holes of the cowl. I started washing it from the cowl and immediatly clogged the drain holes on the side and ran onto the floor boards. No big deal the car is gutted right now anyway I just pulled the plugs. I bet I sprayed 50 gallons of water and removed 10 pounds of dirt and leaves. I took a while slowly cleaning out the drain holes.
Just to let you guys know your cowl might be in the same shape and the leaves and dirt just traps moisture.
