Just so you know, for future reference;
I have a 367/4-speed in my 68 Barracuda, that by it's trapspeed of 93 in the Eighth, is making 430 hp.
The rad is an ancient one that I pulled from a 73Dart with a 318 with A/C. That would make it a 26" 2-row. I installed it into the original slant-6 core support designed for a 19". This rad is now 51 years old; so old that even the patches on the top tank have patches.
The clutch fan is for an early 2000s Ford Pick-up truck;
while the fan is a big 7-blade, also pirated off that 73Dart.
This system is adequate enough that I can run a minimum 207* cooling system temperature, and; it is adequate enough to occasionally run an idle-timing as low as 5* advanced, which allows for parading at 3.5 mph. For however long it takes, the engine-temp remains rock-solid.
The point is this;
my old junk works just fine, even in the 19" core-support.
So, then; If your 3-row rad has to go, to fit a fan-clutch;
for me, that would be of no consequence.
