This is a long and complicated question. So for intrepid Mopar problem solvers, get your reading glasses and here goes:
Last summer I ordered a 10 1/2” McLeod Borg and Beck clutch and pressure plate for my stock ‘69 Swinger 340. I received the scalloped 10.95” PP, an 11”clutch disc (sizes as stated on the packing slip) and the bolts with smaller heads.
After 600 miles, the clutch made a loud grinding noise when the pedal was fully depressed. It turns out that the clutch disc was hitting the bolt heads and that the clutch material and the metal disk in the center were damaged. Also the pilot bushing end of the input shaft was slightly grooved even though the transmission had been recently rebuilt. So I had a new input shaft installed.
When I had the 340 short block rebuilt (the block was from a ‘71 Duster and was recently purchased), I was told by the engine builder that he aligned the stock BH, as I requested. Apparently, he didn’t. So I bought a dial indicator, removed 2 flywheel bolts and checked the BH alignment. It was -.019 off at 4:00 so it needed to move in the 10:00 direction. I ordered RobbMC .007 offset dowels (adjustable with an Allen Screw) because .019 / 2 = .0095.
When I installed these offset dowels, I tried dozens of times to align the BH to within the .004 spec. But I couldn’t get it within -.010 in the 4:00 direction. Next I had the BH dowel holes miked. These holes should measure 1/2”, but were .505. The dowels are .496. So there was .009 slop. I had the BH re-bushed, which changed it to -.022 off at 4:00.
For some reason, the .007 offset dowels still wouldn’t align the BH. This should have gotten it to the .004 spec (.022 / 2 = .011 - .007), but I still showed -.010 at 4:00. I don’t know why.
So I ordered .014 offset dowels. I finally got the alignment to .004. The strange thing is that it should have yielded +.003 at 10:00. But I ended up being -.004 still at 4:00, which doesn’t make any sense, if I understand this correctly.
NOW THE TRANSMISSION WON’T GO ALL THE WAY IN
But at least the BH was within the .004 spec. I installed a Centerforce II 10 1/2” clutch and PP but when I tried to install the transmission many times, it wouldn’t go all the way in by 1/4", which is the thickness of the bearing retainer. In fact, each time the trans was stuck so hard that I had to pound in some shims to separate the BH and the trans. I had the input shaft shortened by 3/8” in case something wasn’t right with the taper in the crank. I reinstalled the Centerforce with the same result. So then I reinstalled the previous McLeod clutch and PP, but the trans still wouldn’t go in all the way.
It appears that the BH is so far out of alignment that the bearing retainer is hitting the BH hole. I don’t know how this is possible, since the dial indicator (verified with a second DI) shows that the BH was aligned.
Now I am wondering if there is something that has caused the BH to appear to be aligned when it is, in fact, way off…. such as something wrong with the stock flywheel or the stock BH that could cause this effect. The BH was obviously way out of alignment to start with, to have damaged the McLeod clutch and the input shaft and caused the grinding noise.
Does anybody have any possible solutions to this mechanical problem?
Sorry I had to write a book to state all the facts that I think may be pertinent.
