Clutch pedal with over center spring removed
deviledchin
Sellersville,Pa
Ok question for you guys that removed the over center spring when using a diaphragm clutch vs. the original B&B. It's a 71 demon with the HD spring.
What keeps the pedal pivot shaft tight up against the plastic bushing when the spring is removed?
It looks as if the spring was actually used as a stop to keep the pedal in and up again the bushing? Now that the spring is gone it looks like it could slide out very easily. Does the tension of the rod keep it place? Did anyone have problem with this and if so what did you do to remedy this?
Thanks, Carl
Maybe that lock ring?
That's it! You are the man! Thanks!
Never even thought to look for that after taking that damn spring off! Wonder how the hell that came off! Crazy
Thanks again!!!
Carl
