sefus
In my constant search for efficiency, I'm thinking about how to keep constant cold/clean air coming into the carb. An open air filter under hood is good till the engine heats up, then you are getting a heat sinked incoming charge temp. A hood scoop helps feed cold(er) air into the open filter under the hood at the cost of aerodynamics of the car itself which takes us to a cowl hood. The cowl I thought was designed to vent hot air out although recently I am reading that people think its to shove air in that hits the windshield then somehow moves backward under the cowled hood. I dont see how that would work but OK.
So my thought is with all the cold air induction kits made for modern fuel injected motors that connects right to the throttle body, why couldnt a carb guy run one of these intake tubes into a bonnet? I know others must have thought of and done this already, heck I did it to a 440 in a motorhome just using a snorkel air cleaner housing, dryer vent tubing and zip ties. I guess my real question would be why not to go this route? If you place the filter directly in the path of incoming air (behind your grill or removed headlight or anywhere it will get constant clean air) it couldnt heat sink.
Thoughts?
-Sefus
Thoughts?
-Sefus
