I was a Design Engineer and am well aware of production tolerances.
Where did you work??? Automotive????
I would be interested in the degrees and lifts of the old Isky and Racer Brown cams.View attachment 1716368894
Here's the specs I have found and use.
1965 180 hp 2 barrel .395 /.405 lift 240°/ 240° duration
1965 235 hp 4 barrel .415 /.425 lift 248°/ 248° duration
1966 235 hp 4 barrel .420 /.430 lift 248°/ 248° duration
Isky E4 .425/.425 lift 260°/260° duration 216° @ .050
Isky's website really sucks. Schneider used to have a few solid small block cams. Small block isn't even listed any more.I would be interested in the degrees and lifts of the old Isky and Racer Brown cams.
Here's one:
Isky # 390160 / Grind B-603
Intake 35-71
Exhaust 71-35
Lift .448"
Duration 286*
Can anyone tell me more about these?
For a 100% I agree with Chrysler's thinking!Unfortunately your assumptions don't line up with measured numbers taken at Racer Brown. They are not comparable to the MP cams and I doubt the wear of 50,000 miles would affect duration as it only reduced lift by .010 of an inch on the intake and exhaust lobes. Jim will tell you that Chrysler liked real slow ramps to save on warranty claims.
That D Dart cam is gettin somewhere! lol273 Commando – (rated at 235 Horsepower)
CAM Valve lift: Intake .425 and Exhaust .425
CAM Duration: Intake 248 and Exhaust 248
273 Standard – (rated at 180 Horsepower)
CAM Valve lift: Intake .395 and exhaust .395
CAM Duration Intake 240 and exhaust 240
Comp Cam 20-246-4 (what I used)
Valve lift intake .468 and exhaust .468
Duration intake 270 and exhaust 270
Here is Comp recommended for my build
Comp Cam 20-222-3
Valve lift intake .462 and exhaust .470
Duration intake 262 and exhaust 270
Isky E4 cam
Valve lift intake .425 and exhaust .425
Duration intake 260 and exhaust 250
And how can we talk 273 without a reference to the D-Dart
D-Dart
Cam Valve lift intake intake .495 exhaust .505
CAM Duration: Intake 284 and Exhaust 284
All Over. Production and Skunk Works plus I worked "in plant" while getting my degree. It does not really matter. Good Engineers are pretty much the same.Where did you work??? Automotive????
Probably helps with less spring pressure required and less higher rpm valvetrain stress.Yep, slower ramps close the valve slower and less force on the seats...
