Comp 901 springs with factory 318 retainers, (with pics)
prorac1
Martin, Mi
Since I have had some questions as to what the final clearances are when using comp 901 springs (or equivalent) with factory retainers, I pulled the calipers out when the springs came in the mail. This way, right, wrong, or otherwise, there will be digital facts on FABO. Here's what we found.
The outside diameter of the spring measured as the manufacturer states. 1.494.
The inside diameter also measured as the manufacturer stated. 1.080. So no surprises here.
Here is a picture of the retainer on the valve spring. It dosent quite reach the outside edge, but it's definitely well supported.
Here's the valve spring without the retainer. It's a thick wire as others have stated.
Here's a pic of the retainer measurement. It was actually much smaller OD than I anticipated at 1.336.
And here's the measurement of the ID of the retainer spring seat area. It measured out to 1.004. A difference between the retainer ID and the spring ID of .076.
So there's the numbers.
I'm going to sleep on it. Lol.
Hope this helps somebody.
Eric
I never doubted you Rob.
Ok…maybe a little. Lol.
But now we have numbers, and my inner geek likes that. Lol.
Thanks again for all the help on this.
Eric
I have used the 901s more than once with stock retainers I just never recorded measurements. lol
I think others have run them for years like that, no issues. It's good to double check.... :)
I was surprised the factory retainer was that small OD. I was expecting 1.38-1.39. But it seems to fit decent ID to ID, so we're good.
Hopefully we will be setting up the heads and degreeing the cam in the next couple weeks!
Cam card.
Good numbers! I was looking for this info a while back.
Quick question- When the retainer is pushed all the way to one side, how much of the spring wire is exposed up top (visually)?
The problem I had with the 901's and stock retainers, is the stock retainers would let the spring make contact with the stock rocker arms. Seemed a little sloppy to me. I used the Comp retainers instead.
How much contact? Was it possible to "clerance" the arm?
I'm assuming these were stock stamped steel hydraulic rockers?
Thanks for the input. We will keep an eye out for that.
This is the retainer slid all the way to each side. It moves about .030 each way.
If we had more spring pressure I'd be worried. But for these little springs I think it will hold up fine.
Hope this helps. Eric
Once it's all assembled I will run the valve train through its cycle and check for clerance.
Aftermarket retainers must be flatter I'm assuming?
We're going to measure everything upon head assembly for max movement/worst case scenario.
I'll report back.
But probably……
Elgin hydraulic that Rob, (Rustyratrod) told us about and had ran before.
Should have the thump we're looking for while still having decent bottom end.
Kit came with cam, lifters, and springs for $184.
And, thanks again Rob.
Eric L
Let us know how that works. I would like to hear that one run.
Eric L
We found a couple YouTube videos of it. But not a lot. But I will tell you this.
It had some shag nasty thump.
So we're hoping to turn the jelly bean 318 into Icky Thump.
We will defiantly have videos eventually……if I don't mess up the install and flatten every lobe on it. Lol
Any cam with close to 300° is going to be a thumper. I'm surprised the @.050 is so mild. The 112° c/l will help with that.
The intake centerline is a 108. Lobe seperation is 112.
The cam in my LSX is less than 10 degrees bigger in duration. Lol
This thing is going to THUMP. Lol
