Console shifter conversion
Did these consoles have a light for the shift indicator originally?
Yes there's a light for the shift indicator. It goes in the round opening to the left of the shifter slide. Here's a pic I snagged from the bay...
One last thought, there are two versions of that bracket that mount on the side of the transmission (the one with the little o-ring hole). I discovered this when I was doing my conversion. I am not sure which one is the correct one for your car, but you will know if it is right once you drop that linkage down through the hole in the hump. And for reference, a 2 3/4" hole saw bit is the perfect size for drilling the hole in the side of the hump. Just something to think about as you are putting it together.
Thanks. This setup came from a 72 Demon so hopefully everything will be the same for my 71. Thanks for the tip on the hole saw bit. I was wondering about what size that was.
Thanks for the pictures of where the light goes on the indicator assembley. So does that just take a push in socket with a bulb? If so do I just wire the socket to come on with the headlights?
Also, can the indicator lens be replaced by itself or do you have to replace the whole unit?
Top plate shined up fairly good with the sos pad but still some gnarly pitting around some of the edges. Can anything be done to fix this other than a rechrome?
Any suggestions? Leave as is and hope the new vinyl overlay covers most of it?
That is pretty rough.... if it were me and on a budget (like most things I do LOL) I would sand and fill the chrome and then have it painted or powder coated. There are some nice powder coats..... and then the vinyl overlay.
On a budget for sure! Ha.
Sand I understand. What do you mean by feel. Powder coat is an option. But I would need to get the console door done as well to match.
Is the pitting and peeling mostly in the flat areas? It's hard to tell from the photos but it looks like the vertical surfaces aren't too bad and are reflecting the pitting on the flat.
If it were me, I'd take some wadded up tin-foil with some water and see how well the chrome that is there polishes up. Then use some masking tape and mask off all the vertical surfaces and sand the flat areas out as good as possible that would be covered by the vinyl inlay. As in the red sections of your photo:
If you don't think any of the chrome is salvageable and want to powder-coat, then things are more difficult. You have to sand everything out really well and then everywhere there is pitting you have to drill out as much of the oxidizing metal as you can before using a filler. Otherwise it will just continue to "rust", pit, and bubble, under whatever you decide to fill and coat with.
Powder coating is a relatively high-heat process so you need to use a filler that is also high heat. Regular bondo and epoxy will out-gas as it is being heated so you have to use stuff like Alvin's Hi-Temp Lab Metal or the coating will come out looking worse than it does now. I've heard people say they've used JB-Weld if the pitting isn't too deep and you can powder coat over it but have never tried it myself. If that is the case, it is cheap and sands smooth great!
Sorry for the wall of text...
If I was made of money I would just buy this - Automatic Console Plate Kit - but holy-crap that's expensive!
Thanks for the tips. How did you do that to my picture? Ha.
Unfortunately that is not a reflection. The pitting does make its way up the flat sides in a few places though a lot of that part of the chrome still shines and looks good.
After reading and thinking about what you shared, drilling and filling the pits sounds like more than I want to tackle with this piece. If I do use it I guess I'll just sand the flat surfaces as best I can, cover with vinyl and hope that the bad areas on the vertical areas do not show up too much.
I know what you mean about that new top plate set. That thing looks awesome but man is it pricey. What a weird number too. $606? Ha.
I don't see where it has been mentioned that you will need your tail shaft to have the two mounting bosses for the flat shifter plate. Here is a link showing what I'm talking about. Not all trans had them.
Moparts on the Web - Main Index
I didn't know that until the guy that sold me these parts mentioned it. Of course my trans does not have the mounting holes. I think it came out of a truck.
I do have a spare 727 that does have the mounting bosses. Is it as simple as swapping out the tailshaft housings?
Wire it into the dash lights. Probably the radio light is the easiest one. You might even find an open connector under the dash near the radio, I believe there is a spare dash light connector there on some cars.
The 4 little prongs are your ground.You can use 57 or 1895 bulbs.
Thanks. I figured that is what the prongs were for but didn't know if it would still ground if the housing is plastic that it pushes into. Good to know on the 1895. I have a few of those around so glad to know they are interchangeable with the 57s.
Thanks for the tip. I think I did notice an extra connector back there when I installed my radio. If so I will use that for sure. If not good to know I can just wire it in with the dash lights.
The Metal tabs have to be ground to metal for the bulb to light.
Hey demon322, I found this hidden along with some other parts. Do you need this or should I offer it up to someone else?
