convertible top motor
Dennis Gerard
Florida/tenn
convertible top motor has anyone come up with a cheaper replace motor for the tops? $229 is a bunch of cash
Hello Dennis
I don't know if you have checked the how to section because it has a very good article on the convertible pump and motor rebuilding in the miscellaneous section. Just a thought. Good luck
Sorry, I didn't go there.
Maybe someone has a good used one for sale. You could start a want add on here for one or watch for a special sale. It happens sometimes.
Yep, that's a good place to start.
I have a nice used one I would sell, a couple of them really. Message if you’re interested!
Virtually any American convertible from the '60s to current pump/motor can be used. I have the pump/motor and rams from a 2002 Sebring. I'm not sure if the rams will work, but I know the pump will.
Yep. 80s and 90s Chrysler convertibles used the same pump and motor, just the wiring connector is different, I believe.
Beyond mounting points and fluid capacity , what differences could there be?
I'd have to go out and look, but as I recall the wiring connector is the same as well. I used the switch, wiring and relays from a LeBaron in my son's Dart with the pump/rams from my Barracuda.
I actually went to a junkyard and got one from a mustang for 25.00 (85ish fox body car) fittings and wiring connectors and mounting were the same plugged it in filled it up and away I went. heck even the 94-2004 (oops 99-04)work if you change connections to match. you can find used all over Ebay. like this one that need a different connection for 89.00 1999-2004 FORD MUSTANG CONVERTIBLE TOP HYDRAULIC PUMP MOTOR 1999 2000 2001 2002 | eBay
