Converting a stock tank to fuel cell
The_night_rider
Sheriff of Rockridge
Reno, Nevada
I was told for my 5.7 hemi I will need a fuel cell. I bought a replacement metal tank about 3 years ago and it still pretty new. I wanted to know if I could convert the tank into a fuel cell and also maintain the stock filler as well because I have a flip cap.
I don't want one that sits in the trunk, I want to stay as stock looking as possible.
How bout using the original inner parts and fuel pump from the vehicle the engine came from would put you in proper perspective I think, what do you think? Probably find a hemi gas tank at the salvage yard just for the tubes, pump etc
You can use the stock tank and modify it for a sump and pump set-up I believe I saw someone said rockland sells the kit.
Why would you need a "fuel cell" just because you are swapping in a 5.7??
