heres the pics
this first one is the main chrome line, if its metal we can plate it here. the closest tank to farthest order is cleaner,rinse,acid,rinse,nickel,rinse,chrome,rinse and the last tank by the guy is zinc
here are some parts we do on the chrome line
tire pressure gauge, this was a rework peice not replated yet
screw drivers big and small, every one is hand racked
these are the blocks on newer doors that lock magnetically
a tub of flat scred drivers
these are gun carriers for ar15's and m16s, we plate the inside then black phosphate the out side after
nickel tank, runs around 110-130 degrees (gets hot in the summer) all the bags are filled with nickel
this is the chrome, nothing special. the copper v is where you sit the bar to make contact, only takes about 10 seconds in there
these are the zinc barrel lines, there are 6 lines in the shop. this is for peices that dont matter if they get scratched while tumbling in the barrel, just getting the coat for protection
all the barrels are air powered, we have two air compressors that are actually big block fords running natural gas
the wood crates are for john deer
zinc and blue
zinc and yellow
some small springs, we run peices small as a half a tic tac
some type of special nail that i believe goes through the wood then welds to metal behind it, one line runs these all day
zinc yellow
zinc blue
some bigger peices that get zinc'd
deck screws get zinc and cleared, probably do 20,000lbs a week of them in a line
thats pretty much the shop in a nutshell, theres a lot of other different stuff we do but we didnt have any of them in the shop today, everyday theres different stuff running from space shuttle control boards to door lock springs for nissan
