Copper Clad Connecting Rods
Dana
FABO Vendor
FABO Vendor
Youngstown
Never seen all 8 before. And they came out of a 383 that was factory .020 overbore.
Those pop up sometimes. Other members have had motors with 8 copper clad rods. I believe they are trying to decrease side clearance between the rods?
I remember a few discussions on here about them. I think @66Dvert was the man with the answers. I wonder what circumstances led to putting all 8 into an overbored block?
Have a 400 at the shop now that is also factory 020 over. It has 4 copper rods. Just a FYI, the factory 020 "440" is not 020 over, it is actually .022 over, which would be a bore of 4.342. Bore size look familiar? Yup, a standard 400 size. Anyway a few copper filled rods for comparison.
I’m guessing a 400 piston and rings with a taller compression height? I had a 1972 400 hp short block once that the pistons were just barely below deck, about.015 or so, so I’m thinking it was probably the same piston. I apologize for the de-rail, but folks I’ve talked to who have owned 400 HP that did the old school performance mods (TM6, headers, Crane Blazer 288/.480 cam, distributor recurve) claim it was more like a 340 than a big block. A whole of fun in a ‘72 charger with an automatic and 3.91 gears.
Copper builds up the flawed rod id so it can be machined again to a std bearing insert OD or side clearance. It's just a cheap attempt to save a flawed rod. Works.
40 over 440 pistons getting stuffed in a 400 today, which is 18 over for the 400. Here's the 4 copper filled rods. Bobweight at 2694 grams JUST makes it for an internal balance.
I’m all ears
I’m not being a smartass or looking to argue. Just want to do what’s best. I’m all ears. Building a 383 about 500Hp, A body, stick shift. Thanks
Which 440 pistons will work in the 400? What compression height?
I’m all ears
Copper is soft. It was a bandaid to save a nonconforming part. Big end of a rod? add weight? What happens when the copper peels off? Where does it go? With everybody pitching stock rods, someone should have a good set you could get. I'll go through my stash of parts. I know I have extra RB rod sets but I have to check on 383 rods.
I have not gotten the pins pressed out yet. There is no copper visible in any of the big end saddles. But the rods were only machined on the side that rides against the other rod. I’m beginning to think that these particular rods were clad in order make up side clearance.
It's done at the factory to make a sloppy big end tight again with machining ( I believe). Nothing wrong with them at all.
See it alot on old sbf stuff at work.
Could be or they've been rebuilt before
Yes, I've seen it in Chevy and Ford rods as well. Sometimes just on the small end and sometimes the big end, then the whole rod at times. According to some GM engineers I've spoken with, it was to keep from scraping rods that were bored too big on the B/E or S/E and otherwise being non conformance per the specs as 66fs mentioned. Just like the Maltese Cross stamp on many Mopar blocks denoting an odd oversize bore or rod journal size. Any attempt to keep the production moving forward.
