72 Demon - Originally a single exhaust car, but converted to duals at some point in it's life.
I cannot find the
correct dual exhaust hangers / set up for the tailpipes. Maybe what's on my car now are not factory correct...and they've been cut and are unusable anyway.
There are two, by the trunk pan, that resemble a leathery strap part to them.
I purchased a couple of NOS ones off ebay, but they must be for single exhaust cars maybe...The leathery straps are wider than what's on my car, and the u bolt is way smaller than my 2 1/4" tailpipes.
Also, and this may just be an aftermarket issue, but the driverside bracket welded to the floor pan, doesn't seem like it's going to line up to the backside muffler/pipe...unless the hanger has A LOT of play / range.
I cannot find the
sometimes you gotta do whatcha gotta do..!
I referenced Muffler hangers. As said you need tip hangers if using chrome or stainless tips.
