abodyjoe
i hate that stock coupler.. i swap to the flaming river joint.
You need to at least un bolt the column so you can pull it back.
Can you rebuild the coupler with the column and steering box still in the car?
I leave that pin in place and just use new shoes. Ive never seen a worn pin and they are a real pain to remove.
What methods have you guys used to press out the steering shaft to shoe pin? The column is still in the car and I doubt trying to hammer it out would be good for the steering shaft.
