dgswinger
Well I was taking my heads apart to clean them up and start to do a little port work when I found this crack at the top of the guide under the spring. Any opinions as to how to fix or is this fixable? Should I be concerned or is this ok? The heads aren't anything special just 587 casting 360 heads. Not sure if they are worth investing alot of money into, considering what's available now for small block heads. Take a look at the pics. It just appears to be cracked on the outside not into the guide yet. Any and all input is appreciated. Thank you.
