ScubaSteve
Active Member
Okay the car is a 74 dodge dart swinger, 318, with a A904.
Im having quite an issue here. okay back story. it had been sitting for a while because i was on vacation, i had moved it to wash it, cranked over and started fine. When i went to move it back, it cranked but battery was dead, so i hooked up jumper cables and let it sit there and charge the battery a bit.
Car still wouldn't start, so i pushed it back to its resting space.
Afterwards car radio wouldn't turn on, no accessory's no nothing, not even cranking. okay, so i replaced ignition switch, okay cool i got cranking. still no start at all, so i ended up replacing, (stuff needed to be done anyways) starter, coil ballast, ignition control modual, spark plugs, wires, dist, coil, wires, voltage regulator. still no spark even with an inline spark tester... what did i do wrong? please get my girl on the street! aha
Getting tons of fuel, i see it spray into the carb, and the see thru fuel filter is filled with fuel.
