340dartley
- Joined
- Feb 4, 2007
- Messages
- 519
- Reaction score
- 170
I have a 340 block in my garage that I would like to get running on the cheap. I don't want to cut corners per say but would like to clean up and use existing parts that I have.
My current concern is the crankshaft. It was in good shape and fresh .010 mains and rods when it was removed. It wound up sitting outside and became rusty. I glass beed blasted it and would like to repolish the journals and run it. Machine shop said if it was beed blasted it will have to be turned. Anyone ever home polished a crank or should I have if turned. I also need one 340 floating rod as one spun a bearing.
