stumper
NO header collector at all.that would interfer with my O2 sensor......mine tap into the valve cover and then go to the catch canister...total cost was 277.98...all fittings and lines included....was told by my buddies and others this was the way to go....and have to say so far not a problem....and the canister has a drain at the bottom..a petcock like a radiator has and my radiator overflow...the breather is open element to the atmosphere all the time ...yes...
I'll get the name for you if you want...I didnt ask...my buddy got it all for me and we put if on.....easy install...1 2 3 done...
wayne :burnout:
Ahhh, ok now I got it. Yours isn't vacuum assist - just using the separator as the common vent. I thought you were pulling some vacuum on the can and was surprised at the breather vent on it.
That is a good system you have instead of just breathers on the valve covers. At least you can contain the oil vapor instead of it getting all over the engine bay.
I was thinking of doing something similar with the header evac system. Running a separator before the headers to keep the oil out of the exhaust. Of course with vacuum it would not have a breather vent like yours.
