Corrupt_Reverend
While I was replacing my oil pump, I noticed my tie-rod ends were toast so I replaced them.
I installed the new ones as close as I could to the old ones and the tires seem parallel to eachother as best as I can see. There's an alignment shop down the road from my house so I figured it would be good enough to putter over and get an alignment.
After I got the motor running, I took it around the block. While driving, I noticed something was waaayy funky.
Going straight, the car tried like hell to veer left and right. When turning, it tried to bury the wheel in the direction of the turn and when I drove with the driver's side tires on the yellow line, I could the front tire was screeching.
I turned around and figured the tie rods were out of adjustment, but when I got back, the camber was insane. The front wheels looked like they belonged on a slammed mini truck.
Just guestimating, I'd say the tops of the tires were a goon inch inboard of the bottom.
I tried shaking both front wheels side to side at the tops. The pass felt solid, but it seemed like the driver's side wheel had a tiny bit of wiggle.
It was getting dark so I didn't have a chance to get a look under the car, though I don't know much about suspension so I'm not sure I'd even know what to look for.
So, do y'all know of anything that could cause excessive camber after replacing all four tie-rod ends?
I'm going to swing by the alignment shop tomorrow and ask them what they think, but until then... any ideas?
