1972Swinger
Hey guys. I really need some input on something I wrote. First, lets say I am an aspiring Automotive journalist. Always been my dream to be able to make a living just looking and writing about cars. I have to write something for my English class at school, and the teacher said I could write a fake magazine article about a custom car. I decided to write this:
Jeremy's 16-Plug HEMI Sedan
A Not-So-Average Enthusiast Builds a Not-So-Average 4-Door
What does an average MoPar guy think when he see's a 4-door anything? "Wow, a 4-door at a show?" They are brushed off as cheap attempts at a custom and barely noticed. But Jeremy isn't exactly "average," so he asks why there aren't more 4-doors at shows. In order to get this idea across, he decided to build a badass 4-door to show those 2-door addicts what a sedan can do.
The guinea pig, a 1970 Plymouth Sport Satellite Sedan, was located by a friend in Idaho, and brought back to Jeremy's garage in Ohio. The original 318/904 drive-train was yanked immediately, to be replaced by something very unique-a 16 plug HEMI!
Now, before all you purists and historians go crazy about Jeremy using a set of rare, original dual plug HEMI heads in a sedan, listen. These are Indy heads machined for the dual plug setup. This was not only easier than locating original parts, it was also cheaper. No vintage drag parts were harmed in the making of this engine, so quit your whining.
This engine is somewhat amazing in its own right. The block, along with the crank and rods, are factory 1966 HEMI pieces. The pistons are Diamond products .030-over with 9.5:1 compression. Jeremy wasn't building this car for pure drag racing, as he wanted to be able to cruise with it too. As said, the heads are Indy parts, and the intake is a Holley Pro-Dominator Tunnel Ram capped with custom built Pro-Systems E-85 carburetors that somehow fits under the hood.
108 more cubic inches slid in pretty easy, seeing as 4-door cars used the same suspension as coupes and hardtops. A hole was cut in the floor for a 4spd shifter, connected to an overdrive transmission from a '80s truck rebuilt with 18-spline innards by Passon Performance. The rear was swapped for a factory DANA 60 with Moser Axles, a clutch-type Sure-Grip, MP pinion snubber, and 3.54 gears.
The front suspension is stock, except for a Firm Feel sway bar, Firm Feel 1.00" torsion bars, and reinforced lower control arms. Later style Disc Brakes replaced the drums, and 15x6 Rallye wheels fill the wheel wells. The rear suspension is likewise non-impressive with MP Super Stock springs, a Firm Feel sway bar, and Lakewood traction bars. A set of 15x8 Volare Super Coupe wheels shod with G60 street radials put power to the ground.
The exterior is mundane, just as stock. Some rust in the lower quarters was repaired, and the whole car shot with factory W1 Alpine White. A factory Road Runner Air-Grabber hood was painted flat black and put up front. A set of high-back black bucket seats replaced the stock tan bench. The vintage SW cable-drive tach was mounted on a tilt/telescoping steering column from a big New Yorker, and a Tuff wheel was adapted.
All in all, the car has shot down the quarter with 00.00's at 000mph. It has driven to Carlisle and back 2 times, and been cross country. A day at the dyno show 000hp at the rear wheels. Not to mention that Jeremy did everything himself but the bodywork. So, what does Jeremy's car show us? Well, never under estimate that 4 door sedan at the show. It just might be hiding a not-so-average HEMI and a not-so-average driver. +
Pic Captions:
(Front, Low Angle)-Jeremy nicknamed the car "Sedan Dan." Get it? We didn't either.
(Side)-The rake is thanks to a set of Super Stock springs, and cranked down Torsion Bars. Not much was required to bring the 4-door body back to rust-free condition.
(Rear)-Tail lights get shown to coupes regularly. The subframes are connected, and torque boxes keep it from twisting.
(Engine Pic)-Not exactly what you would expect under the hood of a Sedan, eh? The HEMI is dynoed at 000hp and 000ft.lbs. of Torque. Headers are TTI. Ignition is a custom MSD setup, with an Indy Distributor.
(Interior Pic)-The stock dash has a big vintage Kraco 8-track deck mounted underneath, along with a few gauges. Factory Tan interior is spruced up with black buckets and black carpet. Four point Roll-Bar keeps car strip legal.
I don't have actual pics of course. I just made captions for them.
I know it is sorts of weird. But recently I have really started to like Sedan's, and I have always been interested in the vintage 16 plug hemi's. What I need are some theoretical drag strip times and speed, a engine dyno horsepower and torque number, and a chassis dyno horespower and torque number. Anybody got any ideas?
Thanks a ton! Tips would be helpful too.:toothy10:
Pic Captions:
