StrokerMcG
'64 'Cudavert
CUDAVRT gets her new engine and 4-speed. Installed the engine and trans as a complete assembly from below. Easiest installation I've ever done. Engine/trans on k-member, k-member on stand, lowered body over stand.
It is a pro-built 273 (+030). Engine, trans, and soon a re-built rear axle, all out of a Barracuda. Also 4 wheel disc brakes.Car looks great. What size engine are you using? If it's a 360, make sure the center link doesn't hit the oil pan on a left turn. It'll wear a hole in it. I found out the hard way.
Stroker
