!!!DANGER!!! !!!WARNING!!! Exploding A/C clutches!!!!
67Dart273
Idaho
Heh.........I admit the headline was to get your attention. This morning, started to finish the engine conversion in the White Whale III to add an A/C compressor
Went through the "pile," and I've lost count. Two were earlier TBI era compressors.....completely different mount and hookup. One both clutch and compressor are completely frozen. One turns but "grates." The last two THE CLUTCHES TESTED SHORTED..........which brings me to........
How NOT to blow up your A/C compressor clutch!!!!
It turns out that (at least on the later Dodge RAM/ Dakota/Durango) that there is a spike protection diode IN THE PIGTAIL of the compressor. If you TRY TO BENCH TEST this by hooking 12V to the clutch, AND IF you get the battery polarity incorrect, YOU WILL SHORT that diode, and "easy to assume" the clutch is "bad."
(A normal clutch reads upwards of 3+---4 ohms. A shorted diode reads a fraction of an ohm.........)
But I'm suspicious. So I cut the pigtail in half, pulled the protection sleeve off, and........................
(Cutting the pigtail............I would not have done this except this will be "underdash" hang on NON OEM air. So the original harness connector will not be used)
I retrofitted a 1990's era Mazda MPV (had been an Alaskan rental car) with a complete A/C system from a junkyard. Before getting it charged, I bypassed the low-pressure safety valve to see if the compressor would kick it. It kicked in alright, for a few seconds, then locked up. Spent a couple hundred dollars more for another compressor, then everything worked as it should. Assumed I destroyed the compressor, probably did.
^^That's a somewhat different problem. Likely no oil in the compressor^^
Diodes are often put on coils to protect the driver on the circuit that controls it. I'D put one back in.
..........It turns out that (at least on the later Dodge RAM/ Dakota/Durango) that there is a spike protection diode IN THE PIGTAIL of the compressor.
As I mentioned in my post.............yes, I know exactly why it's there........LOL
Anyone want to doubt the validity, "hold onto the test leads when you disconnect the clutch from the battery............
Yep, I was reeeal careful with polarity when testing and installing for this very reason when I replaced the clutch on my '07 Ram.
The good news is I got all the bracket/ compressor installed and the truck running again. Now I'm waiting for the eBay/ Chineseaotionized "throw under the dash" evap unit
Then the fun will begin..........gathering up enough junk to hook it all together. I don't think I have a good condenser out of the "Whale series" pickups (junker was WWII) so I'll use the condenser out of the A body I junked. I'll have to rework those hoses
