MikeD
Been sorting electrics on Duster but still haven't got the dash lights working, all fuses are now good, any ideas ?
With the light switch pulled the orange or tan wires aren't showing any voltage on fuse 7 which is 3 amp, top of picture.
Tail, horn and side lights didn't work, replaced fuse and faulty bulb in rear lights already, cured everything but the dash lights, i've taken the switch out and it looks fairly old but i managed to find another one that looks a lot better so i will try that, wiring looks ok to the switch, fingers crossed.
Just tried the other switch and still not working, lights are fine still but one of the rear lights is slightly brighter than the other, looking at the rear wiring on the drivers side, green twisted to a black and other wires going to a block connector on the other side which i can't find in the trunk and it's hard to see what colour they are.It should be fairly straight forward to jumper power from the main power lead on the switch to the dash light terminal for testing.
The increased brightness of one light could be a wattage thing, as there are a couple different ones to choose from...replace them both. This problem you're having sounds a lot like what I'm going through: I check the orange wire coming up to the dash and there's 12 volts when it's un-plugged, but as soon as I plug it into the circuit board, it goes down to 2volts. Not sure why it doesn't blow the fuse...I've ordered a new circuit board set out of desperation. The fuel gage is wacky also, there's a voltage limiter built into the fuel gage on my 66 Cuda. Since the gage get the current from the circuit board, there could be some connection.....but I'm guessingJust tried the other switch and still not working, lights are fine still but one of the rear lights is slightly brighter than the other, looking at the rear wiring on the drivers side, green twisted to a black and other wires going to a block connector on the other side which i can't find in the trunk and it's hard to see what colour they are.
Your "main point" of interest here is the inst. fuse. The tan wire is feeding power FROM the light switch dash dimmer control TO that fuse. If you cannot get power there to start with, then there's no need (yet) to pull the cluster. Again, that power is provided internally in the switch from the tail circuit
That was my first thought too. Then I thought, easier access the wring harness maybe? You'll need to lower the column to remove the inst' panel and if you have column shift automatic, you risk loosing neutral safety switch setting.
The light switch will pretty much fall from under the dash. Look at the top front of it for a link that has a hole in it before turns straight down to become a scrubber on the dimmer rheostat. That gets 12 volts at switch in park lamp position. Straight below that hole near the center of the rheostat is its inner connector. A nail, instrument screw driver, whatever will fit straight down through the hole to the contact below becomes a jumper, bypasses the rheostat. If the rest of the switch is good, pulling the switch to first or park lamp position should produce full on 12 volts to the tan wire that routes out of the switch and to the fuse box.
