I'm fixing up my 1968 Barracuda. I need a new dash pad. I'm seeing several repop companies. I'm not sure which is the best? FABO members from your experience what "stay away froms" or recommendations do you have? thanks
Thanks for the heads up. I just crossed them off my list.
Thanks Stephen. That's my Cuda.Ok I'm not going to be much help with a dash pad but welcome and if that is your Cuda, Very Nice.
Thanks for the recommendation. Your dash looks beautiful! How long was the turnaround time for yours?My recommendation??
Recover the originals!
Here's a pic of mine, done by Just Dashes.
All three pieces recovered for approx. 1000.00 Canadian. Just redoing the top dash pad would be a lot cheaper. Definitely worth a phone call.
Thanks
Will do. I just went on their website and they are off until Jan 3rd.Just dashes just quoted me 650 ish for one. Let me know if you get a different answer.
I definitely value the quality first. I just went on their website and they are off until Jan 3rd. I'm going to get a quote from them. Thanks again.Thanks!
It took about 3 months but they told me it would be that long when I spoke with them. Work is impeccable, proper density foam was used, grain of the covering is exact, no seams or wrinkles visible anywhere.
ABC Moparts is the best, but like many you will find out that the material everyone uses comes from China and most places do not have that material in stock right now! Once you narrow your list down to three, contact them and ask what the turn around time is RIGHT NOW, do not listen to others who had their pads done in 2019, the times have changed. Call Bob at ABC Moparts...
Thanks. I just went on their website. I'll give Bob a call. Appreciate the advice...ABC Moparts is the best, but like many you will find out that the material everyone uses comes from China and most places do not have that material in stock right now! Once you narrow your list down to three, contact them and ask what the turn around time is RIGHT NOW, do not listen to others who had their pads done in 2019, the times have changed. Call Bob at ABC Moparts...
ABSOLUTELY YES!!! Just dashes did mine about 25 years ago. I think it was about $250 back then, and that was a lot to me. The dash looked amazing 25 years ago when I got it back, and it still looks amazing. Plus, you know it is going to fit perfect because you are getting your dash back.My recommendation??
Aren't there 2 repops offered?
1 is cheap Chinese, lightweight crap.
The other is heavier, better quality, made in the USA and around $700.
Why not try your local upholstery shop? They would be local, saving shipping and you would be supporting a community business. Since you have to remove it anyway....
https://abcmoparts.com/home/ols/products/1968-a-body-dart-barracuda-steel-dash-pad
Another vote for ABC Moparts.
I'll never use Just Dashes again. Very expensive and they don't replace the foam. They just patch the bad spots.
