Dash Removal
Here we go again, is the glass in or out? if its in look up my thread on the subject in this forum it has pics and a step by step.
Andrew
Okay, I am not going to go into the removal issue either but my pics will show you can do all of this WITHOUT removing the dash but you have to strip it all the way down to get good results. Look at the pics and you decide. If your not going for a 100 point show car you can do this the way I did and get great results but there is a alot of work and masking off to do. Good luck!!
Chas.
I know this thread is sort of old as dirt, but Chaz, if you're still out there where did you get that trim for your dash parts? Is that a factory thing or aftermarket? Someone cut up my stock plastic trim to put in a modern stereo, so it looks really bad. Is yours a square type radio with its own faceplate or is the faceplate built into that trim?
