Hey everyone I'm looking for some decent roller rockers in a 1.6 ratio not wanting junk but don't want to break the budget with jesels either. I was looking at the PRW rockers what are your thoughts and opinions on these?
Mark with bullet cams that will be providing my cam suggested for what my build is gonna be to run a set of 1.6 rockers.The main thing is, though, why do you want the 1.6 ratio? The Factory and aftermarket standard is 1.5 and cams are ground to this.
Unless it would be a cheap upgrade to mimic a larger camshaft without actually installing one... there is always that reason.
- boingk
What is your intended use ? ...what cam...solid hydraulic roller or what?...spring pressure?
Rockers/pushrods are one area you don't want to go the cheap route. I use and recommend Harland Sharpe. And on the subject of factory rockers, there have been a few articles on the factory ratio. They have found them to be anywhere from 1.35-1.50.
The cam is a custom grind from bullet cams. Solid roller for a turbo motor that will be going together this winter. Spring pressure if I remember is 300.
I have used the PRW stainless rockers on 600+ hp big blocks with hyd roller cams and over 400# open spring pressure. With proper oiling, set up, and installation protocols, they work very well. Pushrod side geometry is way better than Harland Sharp, or even Hughes. Comp doesn't offer anything other than 1.5 ratio. The PRW aluminum rockers are no different in design from a Harland Sharp rocker, so not so good there. Btw, using a longer valve, as recommended by Harland Sharp, will make the already terrible rocker geometry much, much worse. The shafts need to be relocated to fix geometry.I would suggest avoiding the eBay PRW's regardless any type. We bought a set of the aluminum PQ's with needle bearings (for about $224). The shafts were too soft and had bad grooves in them after 1000 miles, with just .500 lift and about 300# open pressure. The problem is that you may well be getting seconds for any and all of the parts, and the sellers doesn't check the parts out at all; they may just kit parts up from here and there to make a complete set and sell them off.
Ours actually came from PRW (per both the shipping address and the PayPal receipt), although the ebay seller was another name, and claimed they were obsolete production parts that PRW had sold off to them. That was not true, I found out later.
My concern is not with the rockers, B3RE... it is with the sourcing. eBay sourcing on something like this is a possible crapshoot IMHO on what parts you are actually getting..... new, seconds, mixed? We can't see who the OP is thinking of buying from.I have used the PRW stainless rockers on 600+ hp big blocks with hyd roller cams and over 400# open spring pressure. With proper oiling, set up, and installation protocols, they work very well.
Sorry, my reply wasn't supposed to be directed at you. I knew what you where referring to, because I've made that same point myself. I guess I'm too accustomed to the Moparts format where REPLY doesn't include a quote.My concern is not with the rockers, B3RE... it is with the sourcing. eBay sourcing on something like this is a possible crapshoot IMHO on what parts you are actually getting..... new, seconds, mixed? We can't see who the OP is thinking of buying from.
