I have a question about decking a sbm. What have you guys had to have removed in order to get the block square? Is 0.040" to much, what's a safe amount to have removed? I would hate to order a set of KB-167's and find out that the block needs a 0.025" to get it squared. Is there a piston with a 1.790" compression height? I was thinking about running the pistons at zero deck height for compression.
