Wally-T
64 Signet
Hello again friends.
My 64 273 needs a thorough internal degreasing. I'm hoping to do it myself to save some money lol. One problem is that the rocker shafts are clogged with goo, probably from years of old dinosaur juice and poor maintenance. So has anyone here cleaned these out without removing the cup plugs on the ends of the shafts? I've been trying to find a chemical that I can soak them in to dissolve the crap inside but no luck yet.
The other problem is that I don't think I'm getting enough lube to the timing chain. The slinger is in place but I have the cover off and it seems quite dry in there. Also, the timing chain and gears were new about 5000 miles ago and the chain seems to have stretched quite a bit. There was hardly any deflection at all when it was new so I'm wondering if a lack of lube would cause premature stretching. The gears and chain aren't turning blue so no overheating is apparent.
Thanks again, Wally
Thanks again, Wally
