good to know thanksSee that little boss in the rear carb for a vacuum fitting? Consider making that a blow off valve like maybe a big barb fitting with a tight vacuum cap on it. If you ever get a backfire, it may blow off and vent before cracking your top. Ive seen more than one tops that have been "repaired". I bought mine with no top for $100 and made dual and single 4 tops out of 1/4 (didnt last, 2 390 carbs backfired and popped top) and finally 3/8 plate that survived one and only backfire.
Looks like the one that Leanne powder coatedWell it showed up today. Looks awesome.
yep she said its the same oneLooks like the one that Leanne powder coated
was always curious about that myselfWhat is with the buddy bar logo?
Found an older posting (Nov 21, 2018) here on FABO where you asked the same question and apparently it was the foundry that did castings for Edelbrock and Shelby as well.What is with the buddy bar logo?
289-302Found an older posting (Nov 21, 2018) here on FABO where you asked the same question and apparently it was the foundry that did castings for Edelbrock and Shelby as well.
Eye candy. Don't forget, purdy is as purdy DOES!!
They didn’t have there own foundry at the time.Old-timers disease.
Why did they have to use someone else to cast their manifold?
evidence that you CAN make a silk purse out of a sows earThese comments make me feel like a proud mama! Thanks for the kind words guys!
View attachment 1715483110 View attachment 1715483108 View attachment 1715483109 View attachment 1715483107
... except @cawley gets to enjoy the lifetime warranty I extended to the customer who originally retained me to restore it. How many aftermarket vendors would do that?
Awsome thank youWayne, I forgot to mention earlier that the last bolt boss on the base's rear passenger side had to be ground down some due to a casting defect that wouldn't allow the bolt head to sit flush. I cleaned it up already but look there first if you have any installation troubles.
I hope you enjoy many decades of happy service and compliments!
O don't worry its going to be more than just eye candyEye candy. Don't forget, purdy is as purdy DOES!!
O & by the way its going in a 67 barracudaWayne, I forgot to mention earlier that the last bolt boss on the base's rear passenger side had to be ground down some due to a casting defect that wouldn't allow the bolt head to sit flush. I cleaned it up already but look there first if you have any installation troubles.
I always heard them say better than a trip set up but it is all so very particular in it application. An equal 950 cfm carb on a small displacement engine normally doesn’t drive around so well. It drives at WOT very nicely sure! Just the way it was design to do.and the experts always said, 1 good 4 bbl would do just as well, but it looks so GOOD!!!
my dad & I built a 62 polara 500 max wedge clone. It drove & ran nice. 484hp 520tqI always heard them say better than a trip set up but it is all so very particular in it application. An equal 950 cfm carb on a small displacement engine normally doesn’t drive around so well. It drives at WOT very nicely sure! Just the way it was design to do.
Ummmm, how many barrels?my dad & I built a 62 polara 500 max wedge clone. It drove & ran nice. 484hp 520tq
