Does anyone know the difference between a holley 0-80778 700 cfm and a holley 4778-4 700 cfm. They both have same jet size, power valve and are both 4150 type. also both have mechanical secondary. So whats the difference? Thanks.
Mechanical secondaries
Dual accelerator pumps
Manual choke
Two corner idle
Dual feed fuel inlet
1 timed (spark) port, 1 full vacuum, and 1 PCV port
Intended for lightweight vehicles w/ manual trans or automatics with high stall & low gearing
